yeah thats sick thats what im going to get because of power fc dejetro. Anyways the ssintake is there another one made specifically for the map sensor instead of maf? Linky? Any improvements with the map sensor?doridori23 wrote:I have the SSIntake and It looks and performs wonderfully. I am using a MAP/IAT setup with no MAF and it puts the filter in just the right spot. I can send a pic if needed.
The map sensor goes right off the manifold pressure vac line and Apexi will be just the elbow to plate and then filter.nwmrkt wrote: yeah thats sick thats what im going to get because of power fc dejetro. Anyways the ssintake is there another one made specifically for the map sensor instead of maf? Linky? Any improvements with the map sensor?
Thanks!
What you gained in hp you also gained in dirt. They flow more air by having less filtration (unless yours was dirty/full ) and less filtration allows more dust into the intake effectively sandblasting the compressor wheel. Depending on how long you intend to keep the vehicle/turbo this might be acceptable for you. Look at most professional turbo motor builders and look at shat they use for filtration. By professional turbo motor builder I am talking Banks Engineering, Top Secret, Saurus, Tomei, even XS Engineering only use the foam filters for dyno runs and when on the track or street opt for finer filtration. Make no mistake this is not a flame just simply a note to be careful.exode wrote:Shooting for over 400hp? Go with a Honeycomb style filter. Like the Trust/Greddy or an HKS. Generic ribbed filters will work fine up to 400hp after that they tend to choke that turbo a bit. I know this because I had a K&N filter and i gained roughly 8hp after 380 by swapping it for a Greddy.
