C-Kwik wrote:So far fromo what I've read, the limitation is not from the E-Manage itself. I am not as sure about the AFC. But you can set the parameters beyond the 50% limitation. But the limitations seem to be both the ability of the ECU to control the large injectors at low duty cycles. And secondly, issues of ignition timing. When you give the ECU a lower MAF signal to fool it, the ECU will think there is less actual air and will bump up the timing. Too low a signal can cause too much timing advance. The E-Manage can tunes some out, but I don't know how much the ECU would advance it. Too much of a correction factor may put it out of the range of the E-Manage's ability to tune the timing back out.
I should have specified that I wasn't talking about the Emanage, I don't know too much about it. But as far as the AFR and SAFC are concerned, in their features it lists that they can only modify it so much, could be because of the ECU or just the piggyback units themselves...or both.
As for my plan, HKS AFR and MSD BTM all the way. I like modular style, It makes me uncomfortable having something like an Emanage, not able to correct it easily on the fly and such...just MHO.
