HOTWIRE set to: 2-IN 4-OUT.teamloco wrote:Anyone know what the hotwire setting ect is for this thing?
I have an N62 maf and a stock RB20 ecu.
We were messing with the settings and now it runs like poo.
I'm new to the safcII and the manual is ****. Is there a way to recall a previous setting as the car was running fine before my old man started messing with it.
We set the hot wire to 2in and 3out. Now it sputters at higher rpm (timing may be off too btw but not that off). Any one have any experience with rb20det's with an safcii and an 300zx maf?
I tried the search function and read through a ton of install threads but none on actually tuning it.
r32, r33, r34 skyline with rb20det and rb25det uses the same hotwire value.rb25drag wrote:What is the Hotwire setting for rb25 out?
I don't have a manual either.
look on my second link. what else do you need to know! i already gave you the hot wire #'s.teamloco wrote:It doesn't have rb20det listed in the applications. Ill try 2 in 4 out and see if that works better.
did you adjust the iac selenoid correctly ?teamloco wrote: We set the idle set screw on the AAC all the way in and it still idles like this. My timing gun broke so i wasn't able to set the timing.
yes, unplug the brown plug. also check the tension on the throttle cable.teamloco wrote:Do i unplug the brown connector to the aac or just the tps. Because we did this last night and weren't able to get it to idle below 1200. The adjust screw is all the way in as i posted previously. When I back it out the thing idles at over 2k
Stock Skyline 8k tach and safcII read the same.Carl H wrote:where are you getting your rpm signal, safc or stock tach?
Throttle cable is taut, no slack in it. I was thinking maybe some one had messed with the adjustment on the cable too. Ill have to check it out tonight.BoostFab wrote:yes, unplug the brown plug. also check the tension on the throttle cable.
the point is if the throttle cable has too much tensions, it will cause throttle to be higher. try loosen it all the way and see if it let you adjust idling better. make sure the motor is warm.teamloco wrote:
I just got an AUS version of the FSM for the R32. Ill have to see if there is a diagnosis you can run to see if the AAC is working ect.
Thanks for the help guys.
Cool thanks, ill try that tonight.BoostFab wrote:the point is if the throttle cable has too much tensions, it will cause throttle to be higher. try loosen it all the way and see if it let you adjust idling better. make sure the motor is warm.
Carl H wrote:sounds like the idle switch isnt closed then...
hey so if you runnin the stoc maf the hotwire settings should be 4 in 4 out on a safc 1?BoostFab wrote:
2 = z32 maf4 = r32 rb20det ecu
application reference: http://www.apexi-usa.com/pdfInstallation/16.pdf
