rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Fri Jan 28, 2005 5:44 pm
SAFC and SAFC II is a fuel controller, has nothing to do with boost. You are thinking of the AVCR which is the boost controller that looks similar
Ah, yeah the AFC is an air fuel controller, this i already know
It has nothing to do with boost:R U sure about that..??
I am NOT thinking of the AVCR...! I think i know the difference between the 2.
And this is what I copied from APEXi..:
The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
Correct me if im wrong but it DID say intake manifold vacuum / boost pressure.. did it not say that..??
And its funny how my afc displays vacuum and boost but in a different reading scale OTHER than psi
