apexi rev/speed meter
collk88
does anyone have the apexi rev/speed meter? i was looking into buying it but im not sure whats involved in wiring it up to my car. Is it involved? i dont want to get into somthing that i have no idea how to do and i dunno how much a shop would pay to install it for me.
USDM_OneVia
Car: Racing
I have one, it was pretty easy to hook up. It is only 5 wires. If you can hook up a stereo, then you can install this unit. The 5 wires are.....
12V PowerTach SignalSpeed InputSpeed Output (For Speed Cut off demobilizer)Ground
If you are interested in getting the unit, I will post up the KA wiring diagram for you so you know what wires to tap into at the ECU since the instructions are for SR's and CA's. HTH
collk88
alright, cool thanx. wheres the best place to buy it? iv seen it for 220 bucks i think somwhere on the net.
stretch240sx
whats the apex-i comp that is like the superman of all gauges... its got like tach 0-60 0-100....
anyone know?
Exar-Kun
Car: 2005 350Z
yeah, thats the rev/speed meter, its similar to a G-tech...-chet
encasemyheart
So which is the best tuning tool?
Maybe one that measures knock, boost, tach, speed etc. I know the rev/speed removes the limiter.
nismofan14
Yes it removes the limiter but it only removes the one at 120 mph. You need to unplug the 5th gear sensor on the transmission to remove the other limiter. I have it on my 98 240 and i must say that it is very accurate when it comes to measuring times and the other functions.
Ricer240sx
Car: 89 240sx Coupe
sweet, so wheres the best place to find one???
nismofan14
Check rollhard, heavy throttle, enjuku and so on. They all have them i believe. The best tunning tool was the apex i multichecker but i dont think they make it any more but my friend owns a local shop and he said that he can get something like it. Drop him a line at www.acceleratedaccessories.com if you are interested.
UnderPressure
there is a write up in the 240sx.org FAQ on how to wire it up.
Ricer240sx
Car: 89 240sx Coupe
sweet thanx guys :D
