Apexi Power FC With Commander S13 SR20DET 414BN015 L-Jetro Version
Intake, exhaust, fuel injection, sensors, driveshaft, transmission, clutches, flywheels, manual swap components, differential, axles, cooling system, ECU, forced induction parts, catch cans, complete motorsets.
datsun5104dr
Car: 1968 Datsun 510
Apexi Power FC Commander
Used for 3 starts on vehicle, decided to go a different route…
P/N 414BNO15
S13 SR20DET
LOCATED IN CT
OFF ROAD USE ONLY
$975 negotiable
Apexi's Power FC is the industry's solution for tuners who require an entry level ECU standalone at an affordable price. The Power FC is a full standalone computer with complete engine management and control capable of handling virtually any type of engine setup.
The Power FC unit is designed to be plug and play - installation is literally a matter of replacing your factory ECU with this unit. No re-wiring or cutting wires is required.
This L-jetro MAF version includes the following features:
20x20 fuel map adjustments
20x20 ignition map adjustment
Cold start enrichment adjustment
Idle / AC RPM adjustment
Water temperature compensation
Fuel injector size & lag time correction
1, 2, 4, or 8 channel real time monitoring of vital engine parameters
Boost controller add on kit (sold separately Part#415-A013)
Additional features of the Power FC can be unlocked with a datalogit unit (sold separately) or with the Power Excel software used by authorized shops.
Notes:
When using the P-FC alone, it may be necessary to change the initial settings depending upon air cleaner and air flow meter type. (All Nissan vehicles must set initial settings to No Boost Control Kit.)
When using the Boost Control Kit, it is necessary to modify the wiring of the factory solenoid valve.
180SX RPS13 Mid Minor Change
Reason: CLOSED
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
:poke: What's the status on this? Should the thread be closed? :gotme
Return to “Engine / Drivetrain (for sale)”
