Apexi Power FC users, need help with initial startup!
JDMSIL80
So I installed the Power FC + commander, selected the correct air flow meter w/ the commander, and the car cranks up.
However, it cannot hold/maintain idle and would stall just after the engine started to idle. Unless you step on the throttle to keep the revs up, otherwise it would drop right to the bottom.
I have tried swapping both the stock MAF and Z32 MAF, then selected the air flow meter w/ the commander, but still it won't hold idle.
I thought the Power FC comes with a basemap similar to stock, so I could drive my car to the dyno to have it tuned for power. But now I have trouble getting it to idle properly.
I have CA18DET motor and these are my mods:
GT28R444cc injectors255 Walboro fuel pumpZ32 MAFHKS filterFMICTurbo manifold3" turbo backBlitz EBC
Can somebody shed the light? Thanks!
Danskyline
He mate what was the solution to this problem I'm having the exact same issue with my newly fitted power FC
