apexi power fc.... d-jetro?
statickx991
hey i have a 96 usdm s14 and i have a sr20 black top slanted valve cover in it. i want to get the apexi power fc d-jetro so i can use a map sensor insted of a maf sensor. BUT i cant find a place to get the sensor and harness need for that setup. soooo if i get the regualr power fc i will have to use a maf meter, which means i have to recirculate the bov into it so the engine doesn act funny. wut im getting at is there a way i can use the regular power fc and not recirculate the bov into it without the motor stuttering, stalling, and just running weird. or where i can get this sensor and harness
justinmc
Car: 89 240sx LS swap
86.5 Hardbody pickup
9-2X Aero
Usually you can get a GM style 3 bar MAP sensor with the pigtail and wire it in IIRC. No first hand knowledge but just going off what AEM, etc uses. MSD sells a MSD style MAP sensor or I believe Apexi' lists their own MAP sensor in the catalog of accessories.
statickx991
so you think i can get a gm map sensor and butt connector and make my own harness for the apexi power fc d-jetro? and i didnt see any sensors on the apexi site
justinmc
9-2X Aero
I just checked w/ a friend who's an Apexi dealer... he said you can calibrate the D-jetro to run w/ Bosch style MAP sensors... harness is just something you gotta build like you said. He said the calibration can be set for other MAP sensors too. You could always call Apexi as well.
