TurboPulsar »
https://forums.nicoclub.com/turbopulsar-u45596.html
Sun Aug 20, 2006 9:47 am
Yeppers...worked for me too. Just had to find the stock solenoid valve, and it all worked out. the boost seems a lil unstable though..I set it to 1.05, and it kept the pressure spot on for a couple drives, then flew up to 1.3 ! So I'm not sure if I've gotten it entirely right....:S heheI just connected COM to the wastegate actuator and the NO to the intake manifold, also connected the NC connector to the intake between the MAF and turbo inlet...dunno if it really matters..
Have you figured the boost settings btw ? first column is the boost.. the second...is it x100 revs ? And the last column...mostly says 255...know what it is ? Geez, definately would be nice with an english manual ! hehe
