Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Wed May 30, 2007 7:14 am
power FC if you can find one. It's plug and play for the most part and is a full standalone. safc's are bad because as you manipulate the maf signal the ecu is going to different cells on the timing map. unless the safc is used for fine tuning only, it has the potential to do bad things to your engine.Don't know much about the emanage. the ultimate looked neat, but it's still a piggyback controller.
p.s. you're going to have a heck of a time hitting 275 or even 300hp. Do a search for rb25 turbo, there is a thread where someone made 260ish hp, at 16psi. it won't make that kind of power for very long as the turbo's die fast after 14psi.
