Apexi N1 Dual Gaskets HelP!!
vltnolia
Car: Cars, basketball, CStrike,p0ker,and girls
I have a 95 240sx se and i just recently bougt me a used apexi dual exhaust. I jsut want to know where i could get a apexi dual exhaust gasket. I took the upper piping that was connected to the muffler part so i could fit it in my car. The gasket looks really bad and is in need of a new one. I am not talking about the cat convert gasket but the other one that connets the dual pipings to the muffler part. thanks
Anand
Car: 95 Nissan 240SX
don't know.. you might have to go directly to apex-i or maybe get some kind of liquid gasket thing and make your own.. I have heard those are pretty darn good compared to regular gaskets... don't know it from first hand experience so I couldn't tell you indefinetly... but won't hurt to try it.. it will come in a squeeze type tube...black gooe
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
Hrm.... I have used liquid gasket on my intake where the MAFS meets the filter adapter. It works great... but I think it warned NOT to use it on parts that get hot. If you go that route... make sure you read the warnings. If liquid gasket is safe to use on heated surfaces then by all means go for it... because the stuff is awesome.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
call Apex'i up as Anand said and get the gasket from them...some retailers have their gaskets too... or at least they can order them for u.
-Dan
4felix20
Car: Emerald Blue S14
Use a piece of cardboard.
vltnolia
Thanks for all the advices but I am going to play it safe and contact apexi to get the gasket.
vltnolia
will a cardboard acutally work?? or is it a stupid quetion.
MaineExport
Work... maybe. Ever got cardboard wet? Ever heated it up?
Well... in case you haven't.... it doesn't hold up too well. The stock gaskets are steel and the Apexi replacements are foam.
