96_S14_SE »
https://forums.nicoclub.com/96-s14-se-u2649.html
Wed Apr 09, 2003 6:37 pm
The weld is only as strong as the metal its welded to. I mean, if the metal around the weld gives, the weld doesnt mean ****. I doubt apex-i manufactures the tubing they use for the exhaust, so they really cant be held accountable for inconsistancies in the metal tubing itself. Its a basic mild or aluminuzed steel general tube, its not aircraft quality or mil spec type part...
That guy saying hes not going to buy one, becuase a few out of how many thousands have broken is rediculous. Some are bound to give, given the amount of shock and vibrations it sees every single day from every little bump. My suspension is rather stiff and the roads around my rouse are pretty damn rough in areas not to mention the florida paving contractors must be high when they pave new roads now, as every single one sucks worse then before they pave it. My N1 has held up beatifully through this, bottoming out on a drop in the bridge a few times at 80 - 85 mph, various other high speed bangs, a cat at 45 dead in the road nailing it (heard it bouce the whole way back)... Then their was one time the 240 broke down and had to be towed home. When they where putting it into the spot in my drive way the N1 muffler hit the ground mangling the driveway, as it got pushed into the bumper support, but didnt get hurt.
Sorry about your luck, and if you do mig it, make sure their mig is setup for SS welding, as the weld will be compromised, and also rust if not done right.
Edit: to sk8erguy, you said your not getting an N1 but list it in your mods???? Hows that work, or did you grab one in the last 1.5 days?
