So i have a EJ20G swap in my subaru, but its very similar to a SR20 from a S13 as i use the same MAF sensor (z32 in this case n62) same side feed injectors, yada yada yada. I have the following
Apexi Powerfc L-Jetro EJ20G a-CApexi Hand commanderZ32 MafHallman MBC
now since i dont have a datalogit and cant run in map since im l-jetro, if im not mistaken, the map sensor in the boost control kit is worthless since i dont even have one stock.
CN: Could i use the Apexi boost solenoid in the same style as others use the GM solenoid to enable my powerfc to control boost in addition to changing boost settings without the 3 bar apexi sensor?
