apexi gt exhaust? anyone running it?
turboex
is anyone running the almost 4inch apexi gt exhaust? how do you like it? and was it worth the money?
SR180SX
bought one last week, should recieve end of this week, I think it worth the money since it's fully stainless steel and with silencer, will let you know as soon as I try it on!!
blks14
Car: cars
put it on last friday sounds good on the other wise stock ka. totally changed the powerband around but it still has a good low end despite the exhausts size. talked to a guy that had it on a sr he said it was great but the lowend was weak. it went on really easy and fit perfect. I was even able to sneak through the trunk and into the passenger seat to get it home (without the box it is ten feet long).
WickedWS6
That exhaust sounds so good on a stock KA motor, I have not heard in on a SR motor but Im sure it is equally impressive. I would say it is worth the price tag.
ITR_KILLR
why would you put a 3.74" exhaust on a NA car????? 5Zigen makes an exhaust for NA, KA powered 240's
I H8 UR DSM
i was about to say the 240 application is NOT 4"'s : ), 1 its millimeters:) , and 2, its smaller than 4".
:D
SR180SX
I think it's from cat is 75mm -> 85mm -> 95mm..!!
I H8 UR DSM
:confused: huh?
SR180SX
sorry about the confusion, what I am saying is GT spec aren't 95mm all the way, The piping of the GT-Spec cat back system is a very exclusive design. The exhaust starts with a diameter of 75 mm, which gradually increases to 95 mm where the pipe enters the rear mufler. The end pipe (output) is 115 mm!!!!
lowpsi
How much did your GT run you???
SR180SX
got it from local shop $625
I H8 UR DSM
and the whole catback piping is polished, correct?
I have the N1, so only the muffler is finished.
SR180SX
yes, whole catback piping is polished..
battle D
Car: drifting
isnt the gt-spec have 3.74 inch piping and for turbo applications that are running moderate boost
