g-man wrote:Sorry for the delayed response. The apexi fc is set on the stock s14 maf setting. I think this is wrong but when you look at the different settings that you can use on the commander unit it is not clear which setting to use for the z32 maf. Also the rpm's were fine until I installed the apexi fc. I do run a non recirculated bov but it was not rev hunting before I changed ecu's.
Well that's your problem. Your running a Z32 MAF and expect it to run correctly with the S14 MAF selected? It's actually really clear which setting to use. If you go into the "airflow" screen in "settings", it should say:
1. S14 Normal2. Power Intake3. RB254. VG305. VH41
You need to select the VG30 maf. After you do this, start the car and don't touch the gas. The Power FC needs to go through a learning cycle with all accessories off.
