apexi boost control sensor
akhelihoon907
Car: 72 240z
Hey guys I'm try to install a power fc boost control in my rb25det. I have the power fc djetro ecu. Order the boost solenoid and it's harness separately.
I'ma little fuzzy about this part and I can't seem to find a clear answer on Google or anywhere else so if you know of a link please send it this way.
Don't i need a boost pressure sensor and harness to complete my setup? And if so where does the pressure sensor go as far as bolting it to the ic piping?
I bought the motor to put in my 240z so I'm missing a few things and nobody around here seems to know about this stuff. Thanks for the help.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
The boost kit comes with a solenoid to control the boost and a MAP sensor that plugs into the PFC. You run a boost line on the intake manifold to the pressure sensor and wire the boost solenoid to the existing boost step solenoid wiring.
