Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Thu Sep 01, 2005 4:34 am
I just installed my apexi avc-r yesterday and thought i would show a great place to put the solenoid. the manual wants it away from high heat and keep the lines as short as possible.
pressure sensor
i didnt want to put it on top of my fender well, because the vaccuum lines would have had to been long and messy. i saw the harness going to the brake master cylinder behind the strut tower and saw a small hole it used for a fastener. i pulled the fastner out and lined up the bracket for the solenoid, looked like a perfect fit. its a very tight spot so i removed the spring and strut assembly and marked off where to drill the holes from inside the strut tower, using the bracket off the solenoid. i ended up using thick zip ties to secure it. with the rubber "gasket" they supply it hardly can move.
