Category: Electronics >> Fuel Controllers Your Car: '06 Infiniti G35 Apexi AFC NEO
The SAFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
Features include: - Completely new case design - Compact design - Incorporates both AFC and VAFC functions in one unit - 16 point fuel correction - Color FED display - User defined button and background colors - Inverted "anti-glare" screen Key functions include: MONITOR MODE- * RPM * Throttle * Battery voltage * Correction % * Air flow % * Pressure * Karmann * VTEC SETTING MODE- * Air map * Air map graph * Throttle point * Deceleration air * VTEC control * VTEC unmatch ETC MODE- * Model select * Mode select * Car select * Sensor select * Analog scale * Warning set * Display set * Sensor check CONCEPT: High resolution fuel control with integrated VTEC control. CHARACTERISTICS: Revolutionary color FED display easily customized by the user. *Not compatible with i-VTEC for controlling i-VTEC (can still be used as a fuel controller
And the link....
http://www.calienteautomotive.com/produ ... xi+AFC+NEO
