Apex Power FC D-Jetro Info....
ca18det_boy
Just thought I would share something I just found out about this unit. Even though you can't find D-Jetro english instructions I wired everything up according to the pictures. One thing that someone might find interesting is that the signal wire for the IAT sensor is that it needs to be wired to the MAF wire coming out of the ECU...if you wire it up to the harness how the pictures state you will have a crank no start symptom. It took me awhile to figure this out so I figured I'd post up the results so someone might not have to spend the 2 weeks I did to figure this out.
Sabot
I want to get one for my s14 but good info thanks
