yosM45 »
https://forums.nicoclub.com/yosm45-u102168.html
Fri Jan 09, 2009 10:37 am
Just wondering...
1) Have you done the nav hack? If so, is it switched on so the speed sensor is stalled?
2) Use the Advanced options setting, to view the vehicle signal test. It will show you if the speed sensor is on while the car is moving, or if it's off while the car is stopped.
If it doesn't read on while the car is moving there might be an issue with your speed sensor, which is the only reason I can think of why your nav arrow isn't moving.
***To access the advacne settings options, press and hold the settings button, and turn the volume knob a few times.
