Don Keyballs »
https://forums.nicoclub.com/don-keyballs-u5676.html
Mon Sep 08, 2003 5:41 am
Thanks Heath,
I just went to the dealer and found out some of the information. I saw that there are no plug wires, and found out about the timing chain. They wanted 15.00 a piece for the spark plugs! I read some of the posts on this forum and found that there are other (better) plugs available at a much better price. I havent changed the plugs in about 60,000 miles, so I think that it is probably due anyway. I am changing the belts because they are starting to crack. I cleaned the throttle body the other day because the throttle was sticking. That seemed to cure that problem. I haven't changed the PCV before, and I know that it can affect your idle, so I am going to change it. I am starting to think about the fuel filter though as the main cause of the problem.
