I have my car safetied every 6 to 8 months and when they change the oil, they usually have a "once over" and they assure me that every thing is ok and I can't ever duplicate the sound. Today.....yes today, the klunk was so loud it actually sounded like I ran over a hard piece of frozen ice chunk when I was turning...............Slither wrote:Thanks Hox Knightro2
But is steering clunk a serious problem - will the front end drop off?
Or is it just an annoying idiosyncrasy?
Your problem is whatsoever non-related to his issueSlither wrote:Driving Instructor
I had my 'growly' compressor recharged (not replaced) runs much quieter now.
$120 dealer service EVACUATE AND RECHARGE COMPRESSOR. Tech advised noise caused by unbalanced charge on compressor.
You ought to keep a log of all the students that drive your car and note every detail they do that could cause damage to the car. That may help out when you decide to replace that quickly aging V of yours!Driving Instructor wrote:Well, I got the struts mounts done and ...........
NO DIFFERENCE! I still have the noise when I turn to the right!!!
I am running out of waranty..... 160 000 kms is comming fast.
Any suggestions????
It relates to Driving Instructor. We had a common compressor issue which you don't know about.silverarrow27 wrote:
Definitely sounds like a steering or suspension part though. Mine does that once in a while also on right turns mainly.
WHO WAS THE DEALER THAT YOU DEALT WITH?????? MAYBE I CAN HAVE MINE CALL YOURS!!! CAN YOU SUPPLY ME WITH THIS INFORMATION PLEASE. I am still having the klunk and they don't want to do anything more for me......... they always give me a "complimentary" front end inspection but never find it.Vapor77 wrote:I posted on another thread today on this subject please search for it.
To make a long story short. It is the steering shaft link.
I had ALL of the same symptoms described here, took it to multiple dealers, had multiple parts replaced (this went on for months), and had the noise come back everytime until they replaced the steering shaft link.
It is a small shaft between the steering column and the steering rack with a universal joint on each end one of the u-joints was bad. That was what was making the noise.
I now have two other confirmations from others that this same repair fixed theirs as well.
