drifts14x wrote:Hey there guys, I'm putting my JGS manifold in the shop tomorrow to get welded, and I wanted to know if there is anything I absolutely must know before I put my turbo together, hopefully this weekend. I have my S-AFC in, I have 370cc SR Injectors, I have an intercooler, Oil lines, oil pan, blow off valve, basically everything required to install this sucker soon. Now, is there any special things I need to know about the timing, AIV Removal, O2 Sensor Location, anything at all that could potentially cause damage to my car. If it helps, I have a KA24DE, an RX-7 Turbo II Compressor, a 1G DSM Intercooler, and access to a Wideband for tuning.
Wait... you have a twin scroll turbocharger and you are putting it on a typical manifold? Or are you changing the housing to a single scroll?
Install the 02 about 18" downstream of the turbo.
Timing, I would retard the base timing about 5 - 7 degs. if you have no other method of controlling it.
Remove and block off the AIV system.
Your EGR might not like the high pressure of the exhaust system. I would more than likely remove it in your case.
