Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Mon Jan 03, 2005 7:47 pm
Hey thanks. This is probably the only time I have been useful on this board.
Anyway, it is almost exactly like madbouncy described. The supercharger for the T-Bird was designed to make 12 PSI on a 3.8L engine (BTW, it is essentially a Ford 5.0 with 2 cylinders hacked off). So just as you thought Kronik, the pulley must come off the front and a pulley must be found or made to turn the SC to the speeds you want for the boost you want. The pulley on the T-Bird looks as if they all came with a serpentine, which our 240's did not. The easiest thing might be to get a crank pulley made that has all the normal v-belts with an extra nose for a multi-rib serpentine belt. Cheap and it keeps the SC belt out front abd separate from the rest of the system. It will also allow you to simply buy a new pulley for the SC from the millions that are available. Don't forget an idler. I'd pull the idler off the T-Bird and make a bracket for it. You might be able to get away with just making an adjustable bracket for the SC and running no idler. Might be easier that way, but get the idler with the SC anyway, they won't charge you for it. I think.
Its hard to find info, but I am pretty sure the T-Bird SC is an Eaton M-90. It displaces 90ci per revolution (thats 1.5L to you and me). That makes it pretty huge for your low boost application. Here is a complication though. All Eatons have a gear drive up front and I do not know whether it is direct drive or not. In other words, I do not know if one revolution of the pulley = one revolution of the rotors. You would have to find one and turn the pulley to find out. This of course affects the pulleys you need to size. At any rate, with this monster, I would run an intercooler. The volume this thing pushes will move air through it rapidly and the benefits seriously outweigh the negatives.Raising or lowering boost depends on the pulley ratio. It is like saying "size", but a bit more descriptive and accurate.The formula madbouncy gave doesn't seem right. I get all kinds of goofy numbers using it.
For some reason I was using this one:(SC displacement in L * Pulley Ratio * 14.7 / Engine L) - 14.7 = Boost in PSI
That doesn't take into account efficiency losses.
Anyway, I think the Eaton M-62 would be a better match. Maybe we can find one off a different car. Try doing a search on:Buick GSBuick RivieraBuick Park Avenue UltraPontiac BonnevillePontiac Grand Prix GTPOlds LSS
Maybe one comes with a 62. The problem is that they are almost all certainly going to be more expensive that the older T-Bird stuff.
One thing is for sure, the M-90 can take you to much big boost numbers, Hondo.
