JonPowell »
https://forums.nicoclub.com/jonpowell-u5113.html
Thu Jun 19, 2003 11:49 am
So I had my motor running for about 10 minutes and heard a loud pop(I thought it was a backfire). The motor stopped running and I had fuel spewing out of the vacuum line on the fuel pressure regulator. I thought for sure that the pop was a backfire from the motor running rich.
I ordered a new regulator 2 weeks ago and am just waiting for it to come in. I got a used regulator from a 300ZX TT and turns out they are the same(43PSI and bolted right to the fuel rail). I put a clear vacuum line on the regulator just to make sure and tried to fire the engine up today. I got ONE tiny pop and niothing else.
I started tracking everythin to find the problem....Fuel-check, CAS working-check, Igniter-check, spark-check, compression-check except for cylinder one.....NO COMPRESSION AT ALL!
I pulled the timing cover to check and see if the belt slipped and the CAS bracket fell right off, broken. the belt had not slipped, the marks lined up perfect....
I pulled the exhaust cam cover and the CAMSHAFT IS BROKEN!!!!!How the hell did the camshaft break????It broke between the 1st cylinder valves, check picture....Anyone got any idea how this happened, the timing belt DID NOT SLIP....
