Anyone with Dual Exhaust?
rynxprs
Not True dual exhuast....but Dual exhaust that is split back by the rear axle?
Is it possible on these cars.
I had it on my other car and even though people say it loses HP...you can't tell the difference.
I think it looks better personally.
Aries
Car: LT1 240SS
I've seen it done on the 240.Looks alright, but sounds like ***...
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
The Apexi n1 Dual splits into two pipes just after the cat. They follow the same path and both dump out of the driver's side. If you want a dual exhaust that empties on both sides... that's kinda hard to fit in there. The gas tank presents a small problem. There is a picture kicking around, of an s14 with pipes on both sides... looks alright.... but I'm not sure both were even hooked up.
Lobot
HKS DRAGER/DR 240SX 95-98
http://www.stillen.com/sportsc...age=1
if you want the dual...don't know how good they are...
Julio Bro!
Car: 1993 240SX SE, manual transmission, Stillen intake & strut bar, Magnaflow cat + custom cat-back, NISMO sus
You could use a Car Chemistry exhaust insert just before the cat', inside the headers outlet. The insert replaces the muffler for sound control, then its a matter of 2.5" tubing.
sixxdeuce
Car: 93 rx7, G35coupe 6mt
Yes, it is possible, I almost did it on my 95 but I prefer the look of single exhaust on 240's. The tow hook would have had to come out to make it work though. The main reason I decided against it was that the drivers side has the cutout for the exhaust and the passenger doesnt, and i didnt want to hack into my bumper.
I H8 UR DSM
no, the gastank is in the way...and that HKS link, isnt actaully the product you would get for the 240...the S/O in the parenthasis, is for single output only...the dual is not the application for the 240...you would have to remove the gas tank, get a fuel cell, mount in trunk to run the exhaust that way....not to mention the trouble, and ineffectiveness you would have...that H pipe is a giveaway, since its for 6cyl motor...
(thanks nismofreak)
