yup after you took off i went to work on it, couldnt just let it sit there!Andrew300zx wrote:steve- hope that works out for you- cant wait too see it functioningyou were able to get pics up less than an hour after I dropped that off! you may be becoming a NICO addictluck with the swap- should turn out great for you
i will do the best i can to post pics and what ever. i havent found any links with a "how to" from what i know the 2 main plugs connect to the digital, then there are a few plugs for power and some grounds along with a sun sensor.DriftinNC wrote:i was looking into doing the digital swap but i couldnt find any info on how to wire it up, thats the only thing stopping me... iff you find any info or links on how to do it, just post them up here....thanks
thanx it came out of a 92 s13 from what im aware of.twofourzeroSX wrote:what does the digital controls come out of. that looks clean. i want it!
kouki-gymkhana wrote:Good luck with the climate control swap and definitely keep the community posted. I must admit however, that I read on zilvia.net somewhere that a number of people have tried to get it to work but I don't think anyone has succeeded yet. Apparently it's quite a bit more involved than just hooking up the harnesses and splicing a few wires. If I recall (and don't quote me on this) there's an issue with the USDM ECU that spoils the swap. I'll try and dig around a bit and let you know.
Keep at it though!-kouki
thanx for the link, do you know what year 240 he has? from what i can tell i think he has a s14 with a s13 digital climate... thats why he needed all those sensors right?Eikon wrote:I found an old thread here on NICO
http://nicoclub.com/zerothread...ntrol
Looks like there is a lot more to it than just a couple wires and such.
good luck!!!
