rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Wed Mar 15, 2006 6:22 pm
Ok, I just got done converting my setup to a blow thru maf....
Old setup was maf on intake side of turbo, bov on the cold pipe. When this way was recirculated i still had a few times where the idle would drop below 700 rpm and sorta wana stall but not always, but enough times to notice when it did... This was comming to a stop and / or while i would do a high rpm run in that gear and just drop it into N... Other times it would stop at 1000 like its supposed to. This setup ran pretty descent and the best part was keeping the pressure in the system while shifting..!!
This same setup but running open bov i would constantly have idle problems upon shifting into N. It would always drop below 700 rpm and 1/2 the time it would stall out unless i tapped the gas pedal to keep it alive. And when i would do a high rev it N or high rev in any gear and drop it into N it would stall out every time unless i tapped the gas pedal when the needle dropped to about 1000 rpm.. This was expected. When i used the afc dec-air feature it helped out 90 % of the time but was not perfect. The bad part other than the stalling was when i shifted i lost all the pressurized air and i had to rebuild it back up, but considering that i have a .48 a/r... it didnt take long to rebuild..
Now i moved the maf to the cold pipe and it sits right next to the a/c canister thingy by the radiator and the bov was moved to the hot pipe. Let me tell u from the 15 miles i test drove it... I aint felt nothing better than this setup..!! I did about 7-8 high rev runs in all gears and immediately dropped it into N and the needle came down and stopped at 1000 rpm each and every time..!!! Sat at idle and reved it to 6k about 10 times and same thing, needle stopped at 1000 rpm each and every time..!! When the bov vented, it built the boost faster then when i had the bov on the cold pipe even when it was venting to atmosphere.. It was that much of a notice.. I was surprised on how much faster it built up the boost even while venting it out..!!
This was just a 15 mile test drive at 8 psi max (for now) and im IMPRESSED. I give this blow thru maf setup a +++
I guess as the weeks go by ill keep u guys posted on how it turns out.
