I need the following measurements in millimeters please.
The spread on the hub mounting tabs. I need 27mm or larger.
The spread on the two bolt holes in the tabs. I need about 28mm.
The bottom of the spring seat to the bottom end of the strut tube. I need about 90mm.
The spread from each of the three upper mount bolts to its closest neighbor. I need about 99mm.
Please to helping.
