C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Mar 22, 2006 8:53 pm
The revhard is prone to cracking if you don't prep the manifold. Couple thing I did to mine when I had one:
1. Cut the head flange so that each port has it's own flange. The flange stays cooler than the runners and expands less. Cutting the reliefs between the ports will allow the runner sections of the mani to expand without putting stress on the joints.
2. Remove all flash castings. Not a huge concern, but typically, if it will want to crack, it will want to start at a sharp point somewhere. A dremel or drill mounted grinder bit will make this easy.
3. Drill out the head flange stud holes. They should become slightly bigger as you move to the outer most holes. As the manifold gets hot, it will want to expand it's overall size. The heads will expand as well, but not as much as the manifold as the heads will stay cooler overall. If the manifold expands more than the studs from the head to the mani will let it, it may shear the stud off. It could contribute to cracking, but it's likely the stud will break first.
These are actually good preventative tips that would apply to all manifolds. But the revhards are known to crack without good prep. I had got my XS Engineering kit used and the mani came with a nice crack in it. Tried having it fixed, but that only lasted 6 or so months until it cracke3d again and even worse than it was before. My second revhard had all the prep I mentioned and it worked flawlessly.
