Anyone with a HotShot Header, I need a Favor
cory2081
Car: '07 Nissan 350Z
I just got a used Nismo header. The EGR tube on it has been cut b/c the previous owner didn't use the EGR. If someone with a Hot Shot header could measure the length of the small tube on the header and post the length of it, I'd greatly appreciate it. Thanks!!
cory2081
Bump
pr240sx
almost the samae problem with my header (no installed yet) the previous owner ordered from HotShot the header without any emission fitting. The header only has the bund for the O2 sensor and a welded shut one for the AIV.Now my question is, can I redrill my header for the EGR pipeORuse the current O2 bung for EGR and redril for a O2 on the collector so the O2 can "read" from all cylinders?
cory2081
you can do it either way, you will have to modify your EGR tube though so it will reach the O2 bung. I may just clamp the pipe to the pipe that's left on my header instead of putting a new fitting on the header.
