anyone want trade cams?
slw240sx
Car: 1990 Ca18det 240sx Hatch
im looking for some 262 or 264s for my set of 270s . im starting to worry about them being a bit much for my goals since im lowering them due to cost and time constraints. if not ill use em anyways and see what happens .
boost_boy
I have 264s with an 8.5mm lift with excekkent idle and sweet mid-range power. What are yours?
Dee
float_6969
I might be intrested in the 270's. They're a little longer than what I was thinking though. What is the lift on them? I need a big powerband. Hopefully the high comp pistons will carry me in the bottom end and then some decent cams and boost well get me through the rest.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
wanna trade for some stockers? ill do that straight up! just lemme know jon! haha
- tim
boost_boy
Nahhh boys, I think he wants to trade for some performance cams straight-up! I don't think he wants money and wants stockers (could be wrong though)! Well Jon, I would gladly assist you if you want or Ryan could pay you if you want or Tim can square you away with his stockers. We're all eager to see if you really want to do this! Let us know........
Dee
KaZ (VaBch)
What cams would be a good spec for a SC61 turbo & 720cc injectors? I know nothing about cams... I guess I should research them a little... any suggestions? (Cams or Research)
boost_boy
Quote »What cams would be a good spec for a SC61 turbo & 720cc injectors? I know nothing about cams... [/quote] I would say a 264 with a 9mm or better lift. But if you want big power, I recommend a 270 or better with 10mm lift or better which will require you upgrade your valve springs and some cam gears for proper degreeing of the cams. But to be safe, 264s will be just fine.
Dee
float_6969
Stock is 248 right? What is the stock lift?
boost_boy
Correct and the stock lift is 8mm.
Dee
KaZ (VaBch)
Who sells 264s?
float_6969
JUN.
USDM_OneVia
Car: Racing
HKS too.
Joe
biosehnsucht
Tomei makes cams in 256 (8.5mm lift), 260, and 270 (8.8mm both 260 & 270) durations for hydraulic lash (basicly stock) valvetrains and 260 and 270 for solid (need their sold lifter stuff, both as either 9.25 or 10.25mm lift) valvetrains.
Here is their CA18DET camshaft page in english.
slw240sx
these are the tomie 270s with i believe 8.8mm lift. they are rays old cams. i also have tomie valve springs and soon adjustable gears. but im not givin them up
slw240sx
dee what brand are yours. im intrested
boost_boy
Jon,
Mines are HKS units and I will be taking them out soon since my headgasket is letting go (some water in the #3 cylinder). So if you interested, let's do this before I throw in another engine.
Dee
float_6969
Ok, since we're on the subject of cams, can anyone give us a little education? I understand what duration and lift refer to, but what do changes in these variables effect in the running of the motor?
Ex 1 : What differences will I see/feel in a motor running 270*w/9.25mm vs. 270*w/10.25mm?
Ex 2 : What differences will I see/feel in a motor running 260*w/8.80mm vs. 270*w/8.80mm?
slw240sx
dee when you want to do this?? i have the head still wrapped in plastic sitting on my tool box waiting to either come apart or go in the car whole soon as i take my lazy *** to the machine shop with the motor. . . sigh
biosehnsucht
longer duration means the valves are open longer for air to flow in and out, and greater lift means open further.
less lift helps at low RPM by increasing flow velocity for more torque but at high RPM it's harder to flow, greater lift is the opposite of course. duratino is how long the valves are open, longer you're likely to loose bottom end but gain top end flow. It's possible to actually lose some of your intake charge out the exhaust with enough lift and duration on both cams..
boost_boy
Quote »dee when you want to do this?? i have the head still wrapped in plastic sitting on my tool box waiting to either come apart or go in the car whole soon as i take my lazy *** to the machine shop with the motor. . . sigh[/quote] The faster you get them to me the better. I'll have to pull 2 sets of cams from 2 different motors, so I got my work cut out for me. You pay for shipping to me and I'll pay for shipping to you. Email me at: [email protected] and I'll give you my home address.
Dee
boost_boy
Hey Jon,
If you're still wanting to do this, let me know now before I start repairing my woman's sentra. Once I start, I usually try and finish it the same day, so let me know soon.
Dee
slw240sx
yeah.. deff. email me your adress. ill pull the head apart on thursday, and ship them same day.
