Aus450zx »
https://forums.nicoclub.com/aus450zx-u135530.html
Thu Feb 11, 2010 2:54 am
I'm drawing up the files in CAD tonight and am sending it through to the laser cutters tommorow, just thought I'd check if anyone else wanted these as well as it's cheaper to do a multiple run.
The gaskets will be the same as the OEM gaskets but made in 1mm copper
the lower runner plate will be 16x44x440mm with the holes laser cut for the ports and bolt holes
NOTE: this suits the pre 94 heads with the dual ports, not the newer style with the oval ports.
I'm also getting a 250x150 plate made up with the TB holes cut into it and another plate cut for the idle control valve but i doubt this would be of any use to others
Price is ballpark but I'd expect about $40 for both copper gaskets and $120 for both lower runner plates. This is laser cut with much better tolerances than jet cutting. Price is in Australian dollars and the exchange rate is favourable to the US at the moment. They wouldn't weigh much so I'd be suprised for postage to be over $25-$30
