Anyone want a part designed?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I am currently taking a CAD course in college using Pro/Engineer.... I have to create something on the CAD program for my final project....
I have a lot of Q stuff left... It cant be too complicated (like I cant CAD the entire car or something) but it cant be something really simple... Something with 5 or more parts...
Any suggestions???
Raxephon
Car: '04 RX8...for the moment...
Front driver-side suspension components
Shift Lever Assembly for the transmission
Hood, locking mechanism and lifting mechanism
Or are you looking for something a litlle more simple/complex?
SSDwellah
Car: '90 Z32 Coupe w/ VH45DE + 5-speed (FOR SALE)
'06 Infiniti G35 Coupe 6MT
'08 Frontier 4x4 SE KC
Maybe you could make something better than the VH45 "spider" intake manifold.
Perhaps with some practice you can make something like this dual plenum:http://www.zparts.com/showcase....html
I think some of the earlier DOHC nissans have a lot of potential locked up in the intake manifold like the KA24DE and VH45DE. I mean look at the VG30DE in the versus the gen 1 VQ30DE in the maxima. Both are 3L and the VG makes 222HP while the VQ only makes 190HP. Okay so you may say, he bore/stroke numbers are different and the VG has VTC so thats whats the reason behind the power difference. Right? Well then look at the gen2 VQ30 versus the Gen 1... we're back to around 220HP with the major change being the intake manifold.
I'm not sure how discrete the 5 parts are, but maybe they could be.
1. Lower IM (one piece for cheapness, but two seperate internal chambers for decreased turbulence)2. Upper left IM3. Upper right IM4 & 5 Thottles and linkage.
Maybe you could design something trick and powerful that would (at least come closer to) clear the stock hoods of a Z32 or S13 when swapped in.
A lot of work but could be worth it
elwesso
2007 BMW M Coupe
I dont think iwas clear... Im not really desiging a part, im taking a part that already exists and drawing it in the CAD program. From this, you could take it and have machined or cast....
elwesso
2007 BMW M Coupe
so far my thoughts were:
1. A Z32 caliper2. A Hub (spindle with wheel bearing)3. Power steering pump4. AC compressor
Raxephon
3. Power Steering Pump
TXCumtrensh
Car: None
If your goign for something easy, hows about a wheel spacer? 5x114.3 bolt pattern, 20mm thick!... easiest thing evar!
or those brake caliper brackets (made to extend the caliper for larger rotors) they look pretty simple to design.
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Model the M spec 4 pot calipers, pads & discs. There's more than 5 parts to them so you can do a nice job of it.
ultrapulse
Car: z32 300zx, Hilux & Datsun utes
All those little courves and ribs will make life fun i'd imagine.
elwesso
2007 BMW M Coupe
Mettler wrote:Model the M spec 4 pot calipers, pads & discs. There's more than 5 parts to them so you can do a nice job of it.
by that i assume you mean the Z32 style right???
I didnt think about doing the pads and discs, good idea... may be better to tryand model it with the hub.
Mettler
elwesso wrote:by that i assume you mean the Z32 style right???
Well yeah, though the Z32 isn't the only model to come with those. R32 Skyline GTS-t, GTS4, and GTRs all had them too.
defrag010
you should "create" a VH45 ---> T56 adapter plate
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
you should go to hinsonsupercars and copy their 240sx-ls1 motor mounts...you could make a fat chunk of change too...
SSDwellah
I was thinking about something like that too. Anyone know if the Z33 6-speed trans has a detachable bellhousing?
The T56 is strong but I keep hearing it is notchy and has a bad shift feel but to be fair I have never actually driven a car with one. I HAVE tried the G35 6-speed though and it felt much smoother but probably eventually falls victim to the same brass-syncro issues that many Nissan MT's eventually go through.
Sorry to get off on a tangent there
elwesso
2007 BMW M Coupe
the nissan 6 speeds were apparently redesigned after 04 and the synchro issue isnt as much of an issue... switching to redline MT90 also helps i hear...
the Nissan trans would be a better choice, for the wider gears for higher revving cars.... The T56 has really high gearing... I think the lowest 1st gear is like 2.8:1, which isnt really much different than the Q45 AT's 1st gear...
ultrapulse
I have a t56 mounted up to mine. I have also heard they are notchy. I have driven a 2003 commodore which uses the same box over here in NZ. "our" version seems to also has a crap shifter to make things worse, as the corvette setup I have is much firmer and positive so will have to see how it goes. However I must say That a 2.66 1st gear is a little tall for a street car, and the 0.5 6th was absolutely useless..even at higher open road speeds. I am fitting a 4.4 diff ratio which makes it all work, on paper anyway. It was the cheapest and strongest manual I could find at the time, and didnt know how strong the zed32 box was when i started the conversion.About the z33 trans, no bellhousing doesnt rermove. Also the late z32 (like 98 onwards) trans had different material synchro rings, or so I've read. I havent driven a manual z33, but feedback has been good. I found the pic of the z33 trans to z32 conversion.
SSDwellah
ultrapulse wrote:I have a t56 mounted up to mine. I have also heard they are notchy. I have driven a 2003 commodore which uses the same box over here in NZ. "our" version seems to also has a crap shifter to make things worse, as the corvette setup I have is much firmer and positive so will have to see how it goes. However I must say That a 2.66 1st gear is a little tall for a street car, and the 0.5 6th was absolutely useless..even at higher open road speeds. I am fitting a 4.4 diff ratio which makes it all work, on paper anyway. It was the cheapest and strongest manual I could find at the time, and didnt know how strong the zed32 box was when i started the conversion.About the z33 trans, no bellhousing doesnt rermove. Also the (really)late z32 trans had different material synchro rings, or so I've read. I havent driven a manual z33, but feedback has been good. I found the pic of the z33 trans to z32 conversion.
Yes I have heard about the differences in the late Z32 MT too. I think its only from 1997+, so no luck here in the states. I think the Z32 was made until at least 2000 in Japan but I keep hearing different years (anywhere from 2000-2002). It would have been nice if the Z32 was made here for that long, there would have been almost no Z gap instead of the ~7 years w/o a Z we had here.
Return to “VH45DE / VK45DE / VK56DE Forum”
