WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Jun 27, 2008 4:12 am
Seems to be a complete kit, but you'll want to use a FMU for fuel. Running the stock injectors at 7psi is just to risky in my book. One fluctuation in fuel pressure and you can kiss your motor good by.
It definitly doesn't get much cheaper then that. The turbo is probably a Chinese unit which requires a restrictor to keep the seals from leaking from over pressure. If the bushings crap out on you, you can rebuild it for pretty cheap...say $120 for a garret kit.
WD
