anyone using stock IC on CA?
joe5169
hey everyone....
just wondering how many of yall are using the stock IC and how efficient is it? any problems with it? i'm probably going to start my budget s13 project soon and will want to run the CA completely stock (except for intake and exhaust) for awhile. also while i'm posting, is the SR T28 a direct bold on to the CA manifold?
thanksjoe
Nismo1182
Car: Z06
Im running a SR smic, same thing as the ca one. No problems yet, but it does get very hot, epecially if you up the boost. My CA is still basically stock. Just an intake, stock SR downpipe, 3" test pipe, 3" catback exhaust. Still at stock boost :D
The T28 bolts on, i think you have to make some changes to the oil and coolant lines.
joe5169
thanks nismo...yeah i don't plan on upping the boost until i get a FMIC. one more question: are the SR and CA basically the same deal, or is there an advantage to running the SR compared to the CA side mount?
Nismo1182
Car: Z06
i think theyre are both the same, never seen a CA smic in real life. Maybe the sr one is bigger due to the displacement and more hp? can anyone verify this.
chezina
Yep, the SR SMIC is bigger than the CA one (a few more rows and a little bit thicker).
USDM_OneVia
Car: Racing
I am using the CA sidemount. It's a bit different than the SR one. It looks like the SR has the pipes on the endtank bolted onto it, while the CA has plastic endtanks with the fittings molded onto it.
I will take some pics of it and show you guys the difference.
Joe
joe5169
so does the SR sidemount bold right up to the CA? i'm guessing so since nismo is running one on his CA.
Nismo1182
Car: Z06
plastic end tanks!
Glad i got a sr one for now :pface
NeedCAforS13
Car: CA swapped S13 coupe
joe5169 wrote:so does the SR sidemount bold right up to the CA? i'm guessing so since nismo is running one on his CA.
yes it does...the SR piping works as well. Joe and I both used stock SR pipes, as did Nismo (I think)...
Sean
joe5169
alright...thanks sean
Nismo1182
Car: Z06
NeedCAforS13 wrote:yes it does...the SR piping works as well. Joe and I both used stock SR pipes, as did Nismo (I think)...
Sean
I used my CA cold pipe and the SR hot pipe you lent me.
