Silvia_Ks_90 wrote:
Hey man, I've been running V3's since last season and they are a dream compared to everything else I've owned or ridden in. Quality wise, everything is well put together and can handle our Canadian climate. As well, they come with a lifetime warranty.
Thanks for the feedback. Just out of curiosity, what are your current settings for compression and rebound? I was looking at your pics. What camber plates are you running? Do they allow caster? Any need to cut the shock tower?
s14arlok wrote:I don't wanna go back to the oem kw springs because its too soft.. 6kg front and 4kg rear.. im using swifts 9kg/7kg.
I can't go too soft because im running a rb25 motor, its heavier and if i use the oem springs i could damage my shocks.
True for the front but 7kg for the rear seems really high. The RB is only ~2kg heavier, right? Have you spoken with KW after the install? What lengths did you go with on the Swifts for front and rear? Depending on the answer, perhaps 8kg front and leaving the rears at 4kg may smooth things out? I believe KW configured the setup with an OEM configuration, so that includes a lot of extra weight (OEM battery, AC compressor, condenser, etc...) up front that many replace or remove. If you're running no AC and a light battery, that's getting close to 1kg.
s14arlok wrote:The problem is that if you read the manual carefully you will see that you can't lower the car a lot. You can damage the shocks if you do.
Yep, it's definitely not a lot compared to other brands and going too low may blow a shock. I'm looking at the manual right now and it recommends adjusting the wheel height in the front so the center of the hub is 330-360mm from the bottom of the outer wing/fender, so that's around a 1.2" drop.
