Notchbackca »
https://forums.nicoclub.com/notchbackca-u13338.html
Tue Mar 02, 2004 3:25 pm
just get a CO2 tank if you are gonna use that kinda thing... but a far more cost effective solution is water injection, right after the turbo where the charge is the hottest, use 50/50 washer fluid, I plan on doing a setup on my car with a preasure switch so if I go over say 15lbs of boost it automaticly kicks in. 50/50 is great because the water has a high specific heat, and the alchohol has a low boiling temp... plus alchohol burns cooler than gasoline, and the stuff is like 99C a gallon
