Anyone using a jgs oil feed/return kit?
Projex240
Car: Dogs , My RIDE
I am using the kit, and am looking at the "T" fitting they sent. I was told that the oil pressure unit fomrt he block uses 1/8thbspt, and i need a bspt to npt adaptor. I think they sent one, but im not sure. or maybe its npt already adn they sent a bspt adaptor. i dont know--anyway. Anyone know which fittings form this kit i should use?
-Josh
Projex240
Car: Dogs , My RIDE
oh and also--i read that this was a -4an, and im gonna use no restrictor, which im thinking may cause a problem, but i have a big return line and no kinks at all. So what do you think?
-Josh
fiznat
Car: Grown up :(
you use pretty much all of the connectors they send you... I forget exactly how they fit together but it's fairly simple if I remember right. You shouldnt need to buy anything else to make it work on the ka: I didnt...
As far as the feed line the connections are -4AN but the line itself is -3AN. You should probably still get a restrictor anyways though. I just orderd mine from a non nico advertiser who shall remain nameless (cough) but yeah... Theyre not that hard to find (I'll post pics when I get mine)
Projex240
Car: Dogs , My RIDE
thanks much.
-Josh
fiznat
Car: Grown up :(
heh... this link might help.. er "fill out" my last post... http://www.nicoclub.com/zerothread?id=100846
