As promised:
As you can see, the intercooler has to be shifted to the left a bit for the coldpipe to fit
7MGTE exhaust manifold stud with the included nut on top and the included bracket(cut)
Here is where they should either bend the hotpipe a bit more, or give you a 45degree elbow (I have one on order)
different angle
From the top
This is elbow was not in the kit, and only worked because I am using an S15 turbo
Does not line up 100%, it is off a bit to the right (btw battery tray was repainted to hide the ugly corrosion
Same problem, doesn't line up. The pipe needs to be bend a bit more to the left/right
You can see not all the couplers go on straight, and I was pretty nervous about them popping off or leaking, but I haven't found any leaks yet.
