Anyone use Water/Air IC's?
89turbocivic
Car: Cars
I am planing on doing an SR swap in my 92 as soon as My civic Sells. One of my plans is to run a water/Air IC. The engine bay is setup really nice for it and the charge piping will be shortest possable. Just wondering why I haven't found any disscusion on this topic searching these forums + freshalloy.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I've never seen a Air to Water intercooling setup for the SR.
S13240
You can try using one and have it mounted behind the radiator.
89turbocivic
Car: Cars
Thats my plan. We'll see how it does!
lucky
Car: chicks, cars, computers
Generally air/liquid intercoolers are used on race applications only. I think you would be causing more problems than it's worth by using it on a street car. Stick with the Greddy RSPL or Greddy 3-row if you plan on making lots of power and you'll be fine.
S13240
lucky wrote:Generally air/liquid intercoolers are used on race applications only. I think you would be causing more problems than it's worth by using it on a street car. Stick with the Greddy RSPL or Greddy 3-row if you plan on making lots of power and you'll be fine.
Yes generally air/liquid intercoolers are used on race applications, but there are cars that come stock with air/liquid intercoolers. I say if you got the money go for the air/liquid intercooler set up...don't have to worry about heatsoaking in traffic. :ylsuper
89turbocivic
Car: Cars
Well for the money that most people spend on a FMIC I can do a water/air setup. So cost isn't an issue just wonder why it isn't done more often. I guess I will find out when I try it.
I H8 UR DSM
because for most people in the real world, cost IS an issue... : )
ItzGenX
Where can you get this setup done from?
89turbocivic
Car: Cars
This is where I would get the core from
http://www.pwr-performance.com/page867169.htm
The other parts (Front heat exchanger/oil cooler, resavoir, and pump are easy to come by. Should be able to do the whole setup for around 800.
Daunttless
Also, from an efficiency standpoint for the cost and the size on most applications the FMIC is better... Air/Water setups are mostly used on vehicles where there isn't enough room for a FMIC... Or as pointed out, on a race vehicle but they also use such things as nitrous and dry ice cooling systems.
