anyone use Nitrous with their SR???
New2SR20
Car: 89 240SX
Ive got a Nitrous kit from Holley and its a wet kit... can the SR's withstand any nitrous at all and can the wet kits be used with out motors?
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Run a 50 shot wet and youll be fine. Gatecrasher on Fresh Alloy runs a 50 shot with his 2871R setup and stock internal SR. Ill probably be adding a 50 shot on mine as well.
New2SR20
Car: 89 240SX
awesome 50 shot it is!
1QUICK4
Car: SR20DET S13
I am not 100% sure on this, but I'm pretty sure that with every 25 shot of nitrous you run you need to retard your timing 1-2 degrees. Not sure if that's specific on an sr but I had to do that on one of my other cars.
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
For every 50hp beyond the initial 50 shot you should retard 1.5 degrees. This is the recomendation from Edelbrock, Holley, Zex, Nos, Raptor, etc, etc
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
i was running a 75 shot with3.5 deg retard it went boom and pow clankclankrrrrrgggggrrrrggg pop no more sr
DrifterProdigy85
How was your tuning? What AFR were you running?
TheKon
Car: 2005 Nissan Altima 3.5SE
I plan on running direct port injection with a 100+ shot (depending what will be deemed safe)...and of course a proper tune. My internals will be good for 700hp I'll let you guys know how it works
1QUICK4
Car: SR20DET S13
doridori23 wrote:For every 50hp beyond the initial 50 shot you should retard 1.5 degrees. This is the recomendation from Edelbrock, Holley, Zex, Nos, Raptor, etc, etc
I was pretty sure I was right. Had to throw that out there because nitrous is safe and by far one of the best mods you can get for the money, if it's tuned right.
New2SR20
Car: 89 240SX
i will be runing a 50 shot wet kit from holley..the whole car is probably gonna get tuned at Enjuku racing..so i dont think reliability will be an issue
jbracy7
a jtw cpu. it was rich when it blew up
R-Yahne_240
Car: 92 se coupe stock (dd) 93 se fastback (race car)
jbracy7 wrote:a jtw cpu. it was rich when it blew up
you just had a weak motor my friend was it the rings that popped?????
and did you bounce it of the rev limiter b/c with nitrous thats a no no
(with any driving thats a no no)
New2SR20
Car: 89 240SX
yeah thats a no no with any car...a buddy of mine just ****ed his R32 turbo golf/show car at the track, somehow he shifted from second back to first instead of third which i dont ****ing see how anyone does that..broken transmission and bent rods
