anyone use Akebono brake pads? are they good?
kev1n
looking to order a set from Autopartsworld.com, I ws wondering if anyon ehave any input on them.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
id stick with hawk or OEM.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Akebono makes a lot of the OEM pads to Nissan specifications. Might as well get the correct OEM ones from Joe.
JT_MONEY_2004
Car: 1990 Q45, Pearl
That's the brand Scottsdale Infiniti sold me last yr.
RobertsnewQ
I think Akebono Ceramics ARE the oem application for the Q.
They appear to be very good pads. Hawks are also very, very good pads. I've used the track compound on a couple of cars. 300zx guys like them.
DO NOT get Axxis Metal Masters.
Squeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Falkdesigns
Car: 1998 Q45t ~ EXE
Akebono pads rock. They stop the Japanese bullet trains, and like others mentioned, they're OEM on many Japanese cars. Akebono and Nissin are probably on 99% of Japanese cars as stock.
99q45t_vl
Car: Grey 2014 QX60
Dark Green 99 Q45t - gone
elwesso wrote:id stick with hawk or OEM.
Akebono is OEM on FY33.
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
ke
kev1n wrote:looking to order a set from Autopartsworld.com, I ws wondering if anyon ehave any input on them.
kevin i have been using them for over 2 years now, get the Akebono Pro-Act's they r their top of the line, great pads great stopping power and little dust. the pro-act have the "breather cut" all of the way thru, the shims are great peel and stick comes with the graphite brake quiet. I buy them wholesale for my Q for $63.00 front and less for the rearjames
Q45tech
Only caveat is the temperature limit for Pro Act...........discussed on their own website....[ceramic falling off a cliff temperature vs metallic]............when you decompose oem you will find a small % metallic oxides to extend the ceramic working temperature.
Remember oem has U-91 and U-93 front pad choices which work well with U-85 rear [no choices in rear] ==== Hitachi compounds.
Impossible to find original OEM U-90 pads which stopped in 129 feet.
Something never done is to use two different pad compounds on the same caliper............might be interesting research.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:Something never done is to use two different pad compounds on the same caliper............might be interesting research.
One compound on inner, different on outer? But which in chich location?
Pads seem to wear evenly now, so.......what would be the advantage?
Q45tech
Each pad could have a different friction vs temperature curve [shape] and each pad could have a different friction vs application speed curve.
Q45tech
Microscopic pad roughness vs. squeel...........look and compare with a microscope or even magnifying lens.
http://www.angstrom.uu.se/trib...s.pdf
A negative u velocity relationship increases the squeel propensity and the quality of backing plate determines the bending rate that determines the squeel intensity!
My pads SQUEEL = you bought cheaply made pads not necessarily cheap pads.
http://people.bath.ac.uk/jw254/Assignment%20I.doc
kev1n
well I ordered the Por top of the lines ones fro the F50 and the I, I''ll post my impressions once I install them . to hell with my Autozone crap ones. they aer just too squealy and not the greatest stopping power.
Q_SHIP
Car: 1999 Q45T with a billion miles.
I used Napa brand........United (CMX7566A) full ceramic, $70.49 for fronts. They work on a Y33 Very very well.
Q45tech
There is no such thing as a 100% full ceramic pad.........maybe 50-51% ceramic. composition. All ceramic means is more ceramic than metal or semi metal. oxides.
Q_SHIP
Q45tech wrote:There is no such thing as a 100% full ceramic pad.........maybe 50-51% ceramic. composition. All ceramic means is more ceramic than metal or semi metal. oxides.
Ok then. Well I bought the best I could get.
