Thanks Enigma! That was exactly what I was hoping for in a response. Based on your pioneering efforts and sharing your experiences in this project, you saved us all that first full day wasted in trial and effort. My experience with car repairs / upgrades never went past changing wipers until joining this forum and the education and knowledge shared by peeps like you has been priceless. I'm still no mechanic by any stretch, but I'm no longer hopelessly lost when it comes to car maintenance and mods. Thanks, also, for your detailed info on the brightness, light coverage and install tips! I may make a tutorial with pics as I do this project.
PLUS: I now have an intelligent, charming, and beautiful Italian assitant (Fetucini) who is over 1foot shorter than me, and at just over 100 pounds, she is built for getting into small places, LOL.
Ilya ! Great to here from you, mate! I hope you're out and about doing all sort of tricks and travels on that 2-wheel breezer of yours when the weather permits. We are all still using your FAQ sticky section and are eternally grateful for your efforts to set that up.
I'm wondering though ...
1) are you saying you bypassed the entire existing ballast, installed the 55w ballast outside the lamp fixture, and used the heavy duty relay / harness direct to the battery? And, if so, did you leave the factory bulb connector (that silver bit that turns clockwise onto the old bulb) hanging inside the light fixture? or snip it off and seal the ends. I'm concerened about leaving room for the AFS to function uncluttered.
2) I'm plannng to use the 55w kit and the 6000k bulbs included in the kit. Is that what you used? or did you use the 5000k bulb kit? I understand you get nearly the same colour light either way, but you get more actual lumens with the 5000k bulbs.
Yes, I thought it best to deal with TRS (The Retrofit Source). There are some absolutely brilliant 'copies' out there labelled to match Ultinon and other top quality brands. But TRS is one of very few companies that still gets parts direct from the manufacturer instead of outside distributors so you know you're buying the real deal every time.
For those who are wondering which kit Ilya and I are discussing:
The Morimoto
5FIVE D2S Elite kit:
