Anyone's SR really loud?
stumpz
Anybody else's sr20det loud like mine. My engine bay is filled with sounds of ticking or clicking..can't really tell but to me, it sounds like my injectors are just loud. i know my ka24de's injectors were noticable but, the sr's is almost twice as bad.. anyone else?
quiksilvia
Car: 95 s14 se
i have a lot of ticking too, has ur head ever been messed with? the valve lifters can make noise...
stumpz
naw, it hasn't to my knowledge
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
i also get lots of ticking!
nismostate
Car: all sorts of motorsports
Im not sure if it's the same with SR's but maybe you need to adjust the valve's? I know honda's tend to tick a lot when their not adjusted after a certain amount of mi.
DriftS14
My injectors are loud as well. I'm sure it's ok to have a noisy injector or two. Other than that, no noises. (knock, knock, knock)
VitaminT
Car: 93 240sx SE
It is probably the lifters. They get air in them and tick. BTW, nismostate, we have hydrolic (sp?) lifters and they adjust automatically. The up side is not having to adjust. The down side is that they can get unstable at high RPM's. That is one of the reasons you see some Hondas reving to 9K+.
nismostate
Vitamin... your a genius. hehe.
AX75F92
Car: Space
Yup. Its most likely the hydraulic lash adjusters. If they get air in them you have to bleed them, or else they will tick.
quiksilvia
Car: 95 s14 se
i bled mine when i swapped heads in oct last year, so im pretty sure it wouldnt be that on my motor
sgpnismo
yeah it sounds like valve tick, 4g63s get that bad.
ride4lame
AX75F92 wrote:Yup. Its most likely the hydraulic lash adjusters. If they get air in them you have to bleed them, or else they will tick.
how do you bleed them?do i loosen something and step on a peddle? i hope its that easy:)
Hijacker
Car: '92 240sx Convertible
'94 F-150
bleeding usually requires you to remove the lash adjuster and soak it in engine oil, then take a long stick and push in on the plunger a couple of times until it becomes stiff and you can't push it no more. have fun :)
VitaminT
Car: 93 240sx SE
Requires the removal of the valvecover, cams, and rockers.
AX75F92
Car: Space
Exactly what tenkawa said. You need to submerse the HLA in oil and depress the spring loaded plunger inside with a rod of some sort.
Look in the service manual.
Hijacker
'94 F-150
I forgot to mention that HLA needs to stay submerged while you push in on the plunger
quiksilvia
Car: 95 s14 se
yea its fun :)
