Anyone running Supertech pistons?
eh?
I installed these last year in my RB25 and I recently found they have lopped off my oil squirters. Supertech says this is the first time they've heard of the issue. However you are never going to notice a problem unless you check your high RPM oil pressure or do a very close examination of your oil during an oil change.
Here they are
jdmser
Car: duh
Do their pistons come notched for the oil squirters?
eh?
Yes and it seemed to clear when I checked it. Too bad it wasn't enough.
Modified by eh? at 3:20 PM 1/20/2010
jdmser
Car: duh
I think Tomei makes a spacer for the squirters but, I think they only come with their stroker kit.
eh?
My engine is already back up and running, I just blocked off the squirters. I don't think spacers will help, the head of the squirter "bolt" is small as it is and may come into contact with the stock crank counter weight if moved.
I just want to know if anyone has been running them and apparently not many people have.
jdmser
Car: duh
Did you see any increase in coolant temp or oil pressure? I've thought about blocking mine off if my pistons don't give them enough clearance.
eh?
Being they were cut wide open I was getting 55psi max hot with 20w50. Now closed up with an N1 pump I get 90psi max hot with 5w30.
Haven't logged coolant temps, I don't think I'll see a difference.
240drfter
Car: 1990 240sx hatchback rb25det(sold without motor)
1993 vert built rb25det he351cw (for now) in progress
would you recommend these pistons and just knotch a little extra for squirters.....im orderin pistons this week and need to decide which brand
eh?
I guess I would. Notch them and have them balanced.
WhatsADSM
Car: 1998 240sx
Yikes... that is pretty scary.
Glad to hear it didn't mess anything else up once they came apart
