supreamS14 wrote:As long as your injectors/maf are running good, you dont have a $h!t-lode of mods and you upgraded your fuel pump you will be fine! You shouldent make more than 10whp @7psi ! I run my s15 gt28r to 12psi dayly and 15psi at the drag strip with 100 octane sunoco gas( I had my MBC set to 14 psi it creeped to 18psi and melted a piston 2 months ago, I fixed my creep problem and now it will hold boost no problem) on stock injectors and n60 maf. I dont recommend upping your boost as not every body has the same results! Post up A mod list so we can help you before you do this!
s14torps13 every year 7 miles of glaciers from the north fall into the ocean due to global warming
Well, my nephew runs 16 psi using a S15 turbo with no tune, stock maf, and stock injectors. He's been fine for about 2 years dd his car and occasional 1/4 run. I still don't recommend that though.
LOL about the global warming thing. I wish some of that global warming would hit WA. It's more like global cooling over here. It's the middle of June and we still have seen above 67 degrees yet.
