anyone running an A1000 fuel pump??
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
i am upgrading to this pump setup and i would like to get some input on anyone and everyones setup using it..its going in a 95 Zenki
thanks!!!
themadscientist
This one?I would be interested as well as I intend to get one as soon as I get $300 in my hand.
S14-NEO
that be the one...ill have mine tomorrow
BoostFab
Car: S13cp, S13fb, S14z
i'm running one in my setup, surge tank setup; best pump you can get
s13rb28
Car: 1990 nissan 240sx hatch
i also purchased this pump for my set up along with the fuel pump controller, filters and fpr basically the entire set up is aeromotive. but my projects on hold until my crank pulley shows up 8 weeks
s13rb28
oh yeah these are the componenants i'm using.....fuel pump=.......................AEI-11101fuel pump controller=.......AEI 16302FPR=................................AEI-13101fuel filters=......................AEI-12304(100micron) & 12301(10 micron)
themadscientist
Yeah they can be mounted "in tank" too. Good luck getting that big bastard in your tank!
PcCypher
Is the fuel pump controller really necessary?
Carl H
i had enough fun shoving a bosch 044 into my tank, i cant imagine fitting that beast.
s13rb28
well the a1000 is more of a race fuel pump so runs constantly full speed, so if your daily driving yeah its necessary. the pump gets real hot running continuosly so in turn it heats up the fuel.....the fuel pump controller will speed it up or slow it down depending on rpms etc. so if your sitting at a light or stuck in traffic its not just heating up. then it speeds up again when ur on it and the air cools it down.......mines inline there is no way i was fitting it in the tank its not really designed as an intake.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Could you possibably mount it under the car so it gets some nice cold breeze? lol
240z4u
Car: '95 Nissan 240SX
I had one in my 240z. So freaking loud.
Anyway, not the point.
I got mine from a guy, it had been rebuilt. Make sure that pump does not have to pull fuel up hill (mount the pump as low as you can) to keep it from cavitating and overheating.
Worked great for me.
Evan
s13rb28
yeah thats where i mounted mine but there isn't a cool breeze in bumper to bumper traffic or in a busy area with millions of traffic lights??? right so its all good if your ripping along all the time and yes its loud as hell....o well
themadscientist
I am going to use my existing fuel pump to feed a swirl pot that the big un will draw from. I didn't know about the controller, I will have to look into that.
krayton
BoostsFed wrote:i'm running one in my setup, surge tank setup; best pump you can get
been meaning to hook mine up. where did you get your surge tank? i was gonna have one made, but id rather just buy one.
BoostFab
i made mine. owning a tig welder is a big plus.
similar to this: http://www.sdsefi.com/techsurge.htmincorporating a filter.only thing different on my setup than that schematic is the pump that feed the surge tank is that my is the in tank style, the stock pump is sufficient for this task, and the post surg tank pump does all the foot work.
Modified by BoostsFed at 11:17 PM 10/18/2007
S14-NEO
so by utilizing the in tank pump setup you can eliminate drilling holles in your factory tank as long as you are running a surge tank?..if this is so boostfed i think i love you...
Coolwhip
Vendor
I love boostsfed too!
I have been searching forever on my picture folder for the fuel set up pic i drew up but now i see the light.
BoostFab
S14-NEO wrote:so by utilizing the in tank pump setup you can eliminate drilling holles in your factory tank as long as you are running a surge tank?..if this is so boostfed i think i love you...
yes. and much more. if you are into drifting and autox racing; this is the recommended setup for you. the surge tank setup eliminate the problem with fuel starvation with your stock tank on hard turns; and providing a fuel constant availability. remember, i this setup you are utilizing two pumps. a stock one in the tank and the high volumn pump feeding the rail after the surge tank.
Coolwhip
Vendor
hmm and those who stock tank is dented on the bottom and would like to replace it with a fuel cell, would go this route as well?
guyuenvy
I've used this pump fr 2 years no problems...
S14-NEO
i am currently using a Denso intank pump so that pump would more than cover the fuel supply to the surge tank...now all i need to do is find me a nice inexpensive surge tank...
Coolwhip
Vendor
Wait a second, a surge tank doesn't solve our problem with an A1000 pump over heating while out of a tank on a daily driven car. What shall we dooooo?
S14-NEO
BoostFab
Coolwhip wrote:hmm and those who stock tank is dented on the bottom and would like to replace it with a fuel cell, would go this route as well?
depends on the size of your fuel cell, larger ones are basically like your gas tank. using a surge tank added bonus to eliminating fuel starvation.
Coolwhip wrote:Wait a second, a surge tank doesn't solve our problem with an A1000 pump over heating while out of a tank on a daily driven car. What shall we dooooo?
the surge tank purpose isn't to cool the pump, it's for preventing fuel starvation on hard acceleration or cornering
the aluminum case has built in heat sink which help cool the pump. you shouldn't have problem with it mounted in the trunk. another option is you can mount it under your car, the air will help cool it. but i am not worried having it in the trunk.
