Anyone running a SOHC Turbo...best manifold?? PICS PLZ
Fromxtor
Car: 1990 240sx HB
Hey at this point in time im getting machine work done on my engine (KA24E), Port & Polish, Bore .20,ARPs etc . Im trying to iron out the F/I thing so when its done ill be reaqlly to bolt up. Most manifolds ive seen are either cast and log type. MMI is supposed to be coming out with a equal length one but not sure about teh quality. Im taking my time on this project so it will be done right. Other plans are fuel/ignition/engine management, 650cc injectors, JDM rear end w/ LSD, 5 lug, S15 front end, Tien Supsension. Any Pics or suggestions would be appriciated
Import_Ant
our new sponsor IAP makes a nice manifold (and it's warrantied for a year)
I love mine
^there's a picture of it on my engine (while it was still filthy)
it's flanged for a T3/T4, fitment is good, I'd suggest going with a heat shield or turbo blanket though (on SOHC especially) I've burnt through one set of plug wires and a brake fluid reservoir so far. hence the home-made heat-shield and excessive fiberglass wrap.
Import_Ant
here's a picture of their stage 1 kit (from their site) it gives a decent shot of the manifold too. I have a better picture of the manifold but it's on my home computer.
Also, you might look into some KTS coil-overs. I think I'm getting them instead of tein's. They're cheaper and I've heard alot of good things about them.
http://www.splparts.com <-you can buy them there.
Craving4Boost
Car: 91 240sx fastback
hey import what's the update on your car? getting it back together?
Import_Ant
Craving4Boost wrote:hey import what's the update on your car? getting it back together?
zerothread?id=120134
i THINK I have all the exhaust leaks fixed for good. She runs REAL nice and sounds even nicer.
