poshatch wrote:2 way = always locked, same as a welded if you ever driven with a welded
1.5 way (1 shim) sorta like a vlsd, full lock on load, not locked off load (i think)
you can also change the aggressiveness of the lock depending on the thickness of shim you use as well.
You're quite possibly the most ignorant person on this forum.
1) 2 Ways are NOT always locked. They lock 100% under hard acceleration, and lock 100% under hard deceleration. Anything else and they're open. Therefore ideal for daily driving. But most of this half-assed forum can't afford one.
2) 1.5 Ways lock 100% under hard acceleration and lock 50% under hard deceleration. Hense where the ".5" came from.
Shimming a viscous DOES NOT, I REPEAT
DOES NOT make it act like ANY sort of clutch-type differential. Yeah, it might lock harder, but it'll NEVER, EVER lock as hard as a 2 way/1.5way/welded. You're a fool if you thing anything differently.
The fact will ALWAYS remain that viscous' SUCK ***hole for drifting. That's why most associations won't even allow them for drifting (IE Club Loose). They heat up and become useless.
Hell, you can weld your diff for less than you can get a stupid f*** viscous.
People need to educate themselves on this s***; for real.
